Hey everyone,
A friend of mine recently asked me to take a look at her AVR5. She doesn't recall a specific event where it stopped working.
Situation description:
The AVR5 will successfully power on to standby mode when the main power switch is pressed, or at least the power indicator (LED behind the system power control button) will turn amber; this is the normal standby mode color according to the service manual. When the system power control button is pressed, the LED switches to red (protect mode), there is a buzzing noise (I think this is a normal startup sound), and then a clicking noise which I think is localized around the two large, central capacitors, then the system shuts off again. The LED will turn green (operational mode) for a fraction of a second before it shuts off. It then remains red until I cycle the main power switch.
What I've done:
First, I unplugged all loads from the system to ensure there wasn't an external short that was causing it to enter protect mode. Then, I opened up the case and removed all five fuses (verified this was all of them with the service manual) and tested them both with my ear and then with a multimeter, where they all showed minimal resistance. I then checked all of the MOLEX-style power connectors and re-seated them. Finally, I inspected the board for bloated/leaking capacitors or burn marks on other components. No dice.
Photographs of the board and the capacitors that I think the clicking sound is coming from: http://imgur.com/a/caUTU
I also recorded a video. It's quiet, and there's a bunch of interference in the audio (coming from the AVR5 I guess?), but you can hear the clicking sound I mentioned pretty distinctly. I cycle the system power control multiple times in the video: https://youtu.be/ySXJoQSLVms
Oh, and that weird brown stuff around the base of some of the capacitors is some kind of glue I think. It's on a lot of components, and not just capacitors.
Thanks for any help or insight you can provide! I'm pretty new to all of this.
What I've done:
