Panasonic TX-37LX85P blink 3 times
    Re: Panasonic TX-37LX85P blink 3 times
    Voltage is also 0V
    ...the quieter you become the more you are able to hear...
      OK, this indicates a lack of SUB5V. Can you locate that pin on PSU and test.
        I have only at 3 point 5V, all other is 0V.
          Ok, i check power supply board, and i nthink there is a problem in HOT part of the board, i dont have any power outputting the transformators T803 and T804
            OK, there should be a voltage, 17V, always present, but you do not see this?
            How are the voltages at pin 6 and pin 15?
              0V both
                Ok, what voltage do you see at RELAY_5V6 (pin #5)?
                  on #5 pin i have 5.75V
                    OK, that is good. Back to the main board. It isn't turning on the relay signal for some reason. Can you check page 49, in particular these test points:
                    - voltage across C5653 (near IC5602)
                    - voltage across C5655 (same area)
                    We noticed before SUB5V is missing, this is probably causing the 3 blinks now I think about it.
                      IC5602 is near the connector going to the LCD panel if it helps.
                        i test #6 and #15 again with connected clamps when turning on TV, and the result is that #6 have 4.75V for a few sec, and then you hear click and back to 0V. #15 i always 0V
                          Ah, good, some progress, but when #6 is high (after first click, before second), what is pin #20 or #21 doing? Should be 17V.
                            Nope, #20 and #21 os 0V when turning ON.
                            I find IC5602, and i find that one leg of capacitor is broken, (you can see in the picture), and i have no clue how will i solder it back. if you can see that the part of the board is still on the capacitor.
                              Which end (positive or negative) was that lead connected to?
                                negative (the one with red mark)
                                  In which case you can find a ground on the board somewhere and just solder the lead to there.
                                  Closer the better.
                                  I'm pretty sure the green copper area right next to it is ground, you can scrape the soldermask (green layer) off carefully with a screwdriver, then solder to that.
                                    Ok, i solder it to some ground nearby.
                                    Now TV blink 4 times red, no more 3.
                                    i wrote in picture the voltages
                                      Check your wiring, you just shorted that capacitor "470" positive to GND.
                                        Ok, we are now back to 3 blink LED. I solder on wrong place. Check voltages, they are still the same as in the picture above.
                                          Can you check the voltage at pin #4 of the Q5610 device.
