I am repairing a friends Alesis IO2 external USB audio interface cos he damaged the USB socket and bent 1 of the microphone XLRs. Already fixed them.
I thought I might as well replace the larger value capacitors with better quality ones while i've got it.
It has 2 purple Su'scon SL series 2200uF 6.3V caps and 3 orange Su'scon SA series 100uF 35V caps.
I think the 2200uF's are likely to be smoothing caps so I think I can safely replace these with low ESR ones.
On the Su'scon website the SL's are under standard and are general purpose but the SA series is under special. What should I replace the SA's with?
Also, there are 4 47uF 63V audio coupling caps in series with the MIC XLRs.
On channel 1 they've used Su'scon SL's. On channel 2 the manufacturer appears to be DON with the flat side of the "D" thicker than the rest.
I've never heard of this make before. What should I replace these 4 with?
I've always thought the lower the ESR, the better but since these are in the audio path, I thought maybe not. What will give the best audio quality?
New electrolytics or another capacitor type entirely?
The rest of the caps are all tiny 22uF 16V DON's.
