Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > General Electronics Technical Discussion
Thread Tools Display Modes
Old 06-19-2017, 09:19 AM   #1
socratez
City & State: TX
My Country: USA
I'm a: Knowledge Seeker
Default Solder 80/20 PB/Sn
I picked this type of solder at the dollar store. Can i use this alloy to hold components to pcb?
On the wiki, it mentions it can hold radiator fins together. Which is usually copper or aluminum.
Am I correct that it has a wider temp range to solidify so it can cause broken joints more likely to form if not held steady?
socratez is offline   Reply With Quote
Old 06-19-2017, 10:19 AM   #2
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Default Re: Solder 80/20 PB/Sn
Normally there is 60/40 Solder for electronic work...Solder does not hold aluminum together.
Andrew F. Ali is offline   Reply With Quote
Old 06-19-2017, 10:42 AM   #3
eccerr0r
Fried
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Lead is cheaper than tin, that's perhaps why it's at a dollar store...
I wouldn't use this stuff if I can avoid it. Yes it may stick but you have to be careful as likely you'll get cold joints if you touch it even slightly while cooling and not have clamps to hold the parts steady during cooling.
eccerr0r is offline   Reply With Quote
Old 06-19-2017, 10:49 AM   #4
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
80% lead sounds dangerous,
it may be for soldering metal panels together prior to finishing - like for car body's
stj is offline   Reply With Quote
Old 06-19-2017, 02:17 PM   #5
eccerr0r
Fried
City & State: CO
My Country: USA
Well it is used for copper radiators, I'd imagine car bodies are welded not soldered.
I don't think welding copper works very well in air...
Old 06-19-2017, 02:20 PM   #6
petehall347
City & State: worcester
My Country: United Kingdom
car bodies used to be lead filled along the seams . also for filling dents and rust holes .
copper can be spot welded .
petehall347 is offline   Reply With Quote
Old 06-19-2017, 05:03 PM   #7
socratez
City & State: TX
My Country: USA
Ok, thanks all. I'm not going to use it.
Old 06-19-2017, 05:11 PM   #8
petehall347
i have been using this spec with no troubles at all ...MBO 0.7mm Wire Lead solder, +183 → +190C Melting Point, 40% Lead, 60% Tin,
Old 06-19-2017, 09:42 PM   #9
socratez
City & State: TX
My Country: USA
@petehall347, thank you!
Old 06-20-2017, 01:38 PM   #10
R_J
City & State: ☻
My Country: Canada
Just make sure its NOT "acid core" solder
R_J is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
