hey guys, did you managed to recover your lenovo n500?
I have quite similar platform: lenovo g530 3000 with the same mobo flashed with incorrect bios rom.
tomodachi posted wph file, but it's not dump. wph also contains some service information for flasher tool....
anyway - did you recovered your bios by flashing chip using programmer either via crisis disk (or other similar disks)?
Thanks for the files, but I've already disassembled the laptop, soldered out flash and connected it to a Sivava Programmer (Willem) and programmed a correct bin from lenovo off site...
This is the only thing worked for me.
Trying to recover with Crisis disk (lots of various combination) - failed.
Hi! I have lenovo g530 (JIWA3 LA-4212P REV.2.0). After putting damaged ribbon cable for display (I didn't see that flat is damaged in first place) laptop keeps turning off. Just turn on led lights and cooler for few seconds, and turn off. I found that IC power chip (at least I think that is IC power chip) for that few sec was extremly hot. Mark of that chip is 'ene kb926qf -d3'. I think that must change. I need to know is cause or consequence? I hop you'll understand me and answer me Thanks
