Those voltages are roughly double what they should be. Are you sure your meter is reading correctly. Have you measured some of the low dc voltages to see that your meter reads them correctly. CTRL_OE possibly "Control Output Enable" but just a guess.
Slightly low but I don't think enough to stop it working. There will be other voltage test points on the boards. Vsc, VE etc. Can you find and measure the dc voltages at those points.
Ysus or buffer issue then, remove buffer modules one at a time (upper first then lower) and and restest Vsc you might even get an image if one of the buffers is short and you remove it on one half of the screen.
You have Vs meaning relays have turned on the fault is with Ysus or buffer.
Ok so the buffer want bang with a replacement Y sus ? Keep both buffers out and recheck Vsc, what is that voltage doing ?
What about with the Ysus disconnected ? What does Vs do ?
