Samsung ATIV Tablet dead
    Re: Samsung ATIV Tablet dead
    Originally posted by Compute View Post
    In general point is to charge the battery up to the level position , while it recognizes the tablet
    Ok thanks, is there anyway ti check for faulty power IC?
      Hi the battery is now showing 7.5V and the tablet will still not power up even when the AC power is connected.
        capacitor that you shorted , not sitting on the ground both ends?
          Means? I don't understand.. This capacitor was just for the power led. I think we shorted something that powers this capacitor and led.. like a charging IC maybe..
            This capacitor is not short-circuited his two pin now?
              No
                no scheme of course difficult, but nevertheless, look there if the voltage across the board, there is power at the power button?
                  Shows 2.99 Volts
                    Originally posted by Lolomg07 View Post
                    Shows 2.99 Volts
                    hi, how the repair end up going?
                    I have the same problem with the same tablet.
                    on mine, I have 3v on the power btn
                    on the battery connector i have
                    2.25(red bat wire)
                    2.25(red bat wire)
                    2.25(red bat wire)
                    3.0
                    3.0
                    3.0
                    0
                    GND
                    GND
                    Are these measures normal on the battery connector?
                    My battery outputs 7.035V i think this should be enough to boot the device or not?
                    What should i test next?
                    Thank you
                      Yeah, i have same, but i would try program bios...
                      Someone have it? (bin)
                        Hi, I have 2 of the same tablets. Both dead. I dont know what to do with them. No response in both of them. How to check if motherboard is dead?
                          Did you find any solution? msg me at mnz_0022@yahoo.com
