Enough solder on pads here?
    Hey guys.
    This is a QFN32 package. The chip attached, a TPS51120, was damaged.
    When removing it took a bit of solder off with it but not a huge amount. I'm planning on heatgunning the replacement on with flux. Is there enough left on the pads?
    http://i.imgur.com/bPIZ8.jpg
    http://i.imgur.com/mIHIb.jpg
    The black stuff was left by the chip so try ignore it, it's been rubbed off since.
    Also please excuse the picture quality, my camera broke and I had to use this ancient 2MP thing lol.
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    Re: Enough solder on pads here?
    I would recommend using new solder.
      Is there any chance I can use solder paste or similar? Problem is my soldering iron is way overpowered for the job, and I have a tremor, which doesn't mix too well.
      Something like this, thinly spread over the pads? http://www.ebay.co.uk/itm/Solder-Pas...item3cc7dceec2
      Only wishing to bring out the soldering iron as a last port of call.
        QFN should be done with solder paste and hot air as far as I know. Don't think you can really do them with a soldering iron.
        Unless you're confusing it with QFP?
        If it was QFP you could do drag soldering...
        -David VanHorn
          Nah it's deffo QFN. Apparently it's possible to use heavy amounts of flux and sort of drift the iron along to retin the pads. But I'd much rather not bring the iron out :p
          Think I might just have to get some solder paste then. Do I need a stencil for it?
            You shouldn't really need either, if you do it this way: http://www.youtube.com/watch?&v=c_Qt5CtUlqY
            Might pay to practice first on something else I guess
            -David VanHorn
              Found half of an old motherboard (lol) out in the garage with a QFN chip on it. Removed the chip and tried to tin the pads. All that happened was:
              a) All the solder ended up in a big ball in the middle
              b) My soldering iron was way too big/hot
              c) Two of the pads burnt off
              This is the problem I have, my iron is just way too terrible for anything involving precision.
              Surprisingly, I tinned the pads of some other slightly bigger QFP chip using drag soldering, and it worked out okay.
                Just went out and bought myself a nice new Antex C15. Updates soon to follow. :p
                  Okay, just did some more practice on dead boards out in the garage. Replaced several QFP chips (the big SMSC things you see on laptop motherboards all the time) without much trouble.
                  Tried two QFN32 chips, knackered some pads on the one trying to get it tinned, the other went fine apart from 3 leads being untinned.
                  TL;DR - is there any way of getting the QFN pads tinned without all the solder just going to the middle pad? Am I going to have to Kapton tape it off?
                    Guys, just found something that's worrying the hell out of me.
                    The orientation of the chip is supposedly the same in both depictions, yet...
                    The motherboard's schematic suggests that C462 and R458 are to the left (circled): http://i.imgur.com/Nmnk7.png
                    Yet in this picture I took of the chip in question, C462 and R458 are at the bottom: http://i.imgur.com/GxnTM.jpg
                    What the heck! Should I follow the schematic or the picture? I'm now freaked that the (original) chip may have had its orientation markings printed wrong or something.
                      Did you try tinning the pads with the method as shown in the video I posted?
                      I've never done it myself though, but what they did there seemed to work just fine.
                      It seems you need barely any solder, you just want a lightly tinned tip and some flux on the board, then just touch the pads, enough to get some on, you shouldn't be adding any solder in addition to that already on the tip at all.
                      As for the orientation, go by the physical chip. The orientation of any part on a schematic diagram does not have to follow actual component placement at all. The pins for the IC in the schematic need not even be in the same order as the real device.
                      Schematics often rotate or otherwise move components or their pins around to make reading the functionality of the circuit easier.
                      IC markings are extremely unlikely to be wrong.
                      -David VanHorn
                        You're not a real man until you've done QFN32 with 0.5mm pitch by hand. Just use lots, and lots of flux.
                        I did it under supervision from an electronics tech in my internship, he really knew his stuff. But I would do it by solder paste any other day, it's far easier.
                          Gonna mount it the way it was originally then. Seen another board and it's the same. Thankyou!
                          Did it like in the video yeah, I think I need a really fine tipped iron (my current one is 2.3mm and is a tad wider than the QFN pads themselves, hence just coating the middle pad).
                          Surprisingly fun doing QFP chips though haha.
                          Also, just another question while I'm here. One of these is also on the board, a 2N7002DW Dual N Field Transistor: http://www.ebay.co.uk/itm/2x-2N7002D...item19d00ecd44
                          One side seems okay. But the left side, S2 gets nada on the DMM, unless connected to D1. Does this mean the part's shorted?
                          Also, the laptop would shut down if the multimeter touched D1.
