This is a Samsung 50" PN50C450 plasma tv.
These are its symptoms, it just suddenly turned off. When plugged into the wall, you can hear the relay clicking on and off five times before it stops and nothing else happens, no picture and no audio.
After removing the cover on the back of the TV, when plugged in, I can hear the relay on the power board clicking on and off, about one second intervals. Each time it clicks on, the green led on the logic board lights up, then the relay clicks again and the light turns off, repeat x5 before it remains off.
If I unplug the logic board ribbon cable that runs to the power board and then plug in the TV, It clicks on and I can hear the audio of the TV turning on but of course no picture because the logic board is not plugged in, If I plug in the logic board with the TV plugged in, the same 5x relay clicking resumes.
I replaced the power board, no difference, i replaced the main board because of some corrosion i noticed, no difference and lastly I replaced the logic board and still it does the same exact thing.
Any other ideas?
Any other ideas?
