Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 05-19-2017, 10:07 PM   #61
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
I'm a: Knowledge Seeker
Default Re: LG 42LG50FD-AD Intermittent NoGo
Pin 9 PWMCNTL is an open Drain, that MOSFET is normally low (on) but goes high if the Output is higher than the set limit and that is sensed by pin 8 HVSEN which it works in conjunction with VSENSE..
I would check Voltage at pin 7 VINAC since those high Ohm resistors in that sensing network tend to drift in values.
Look at page 10 for 'TYPICAL CHARACTERISTICS'
I did not read the whole spec sheet yet.
__________________
budm is offline   Reply With Quote
Old 05-20-2017, 03:00 AM   #62
Amraks
City & State: Tasmania, Northwest
My Country: Australia
Line Voltage: 240VAC
Pin 7(VINAC) = 4.131v
this is 1 volt over characteristics
Amraks is offline   Reply With Quote
Old 05-20-2017, 09:25 AM   #63
Amraks
Just noticed pin 7 is connected to pin 8. so basically I have just checked voltages on both lines.
VINAC and HVSEN
Old 05-20-2017, 11:19 AM   #64
Amraks
Found some resistors that look low. 7503(7.5m) they test 1000k lower about 6.5m these lead to pin 1 ucc2806.
Also on that pin 7 circuit of the resistor 5101(5.5k) is showing really low about 3.692k.
Old 05-20-2017, 09:22 PM   #65
Amraks
Probed the VCDA and VCDB 500 - 560 mv my understanding this is meant to be zero only 2 mv
Old 05-20-2017, 09:50 PM   #66
Amraks
VSENSE Voltage = 6.59v
Found some more resistors in that network that are 7503's they are all over the place in measurements
Old 05-21-2017, 12:57 AM   #67
Amraks
My bad the 7503s are 750kohms the calculator i was using wasn't very good. rechecked them with a phone app.
They are all over the shop will I have to pull these out of circuit to test as I don't see them in parallel with anything.
http://www.ebay.com.au/itm/200pcs-RK...YAAOSwLnBX5MJI
Old 05-28-2017, 07:36 PM   #68
Amraks
The 8x 7503 resistors have been replaced now the TV works thanks budm for the help you was right about them resistors.
end up replacing the 7503 resistors with Bourns CHV0805-FX-7503ELF
Old 05-28-2017, 10:12 PM   #69
budm
budm's Avatar
My Country: USA
Glad to hear you got it fix, have to watch out for those resistor in the high Voltage section, they tend to drift off the values and cause problem in sensing circuits.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
