Re: Another LC-80LE632U 2-5 thread
What is the P/N of the SWITCHED LDO regulator IC7504 (4-PIN IC mounted on the heatsink closed to the connector CN7501 PD?
You may have bad switched LDO, https://www.badcaps.net/forum/showth...602#post592602
You need to put a load on it using 24 Ohms 10 Watts resistor on the PNL_12V pin (CN7501 pin 1, 2) to simulate 1/2A load first, it should be ablle to handle 1/2A easily, you can also use 12 Ohms 20W to simulate 1A load.
