Hi..The logic board on the Viewsonic VX2235wm-5 Monitor has a voltage regulator with ZCPk on its top...I need a data sheet for it ? Can anybody please enlighten me how one would go about this as I have typed in ZCPk in google and got nothing..Thanks
Viewsonic VX2235wm-5 Main-Logic Board Voltage Regulator
Re: Viewsonic VX2235wm-5 Main-Logic Board Voltage Regulator
Hi..You found a service manual...?? I have been looking for months ..Would you mind giving me a link to it please..re the voltage regulator ....Yes I think its some obscure brand ..I just want to know for sure what is ground on it?? Hk
If its fixed value then checking resistance from a ground point eg the Vga/DVI fixing,will show a short cct.If it is a variable one then there will probably be no Ground, but again you can measure DC volts from the same Vga/DVI socket,and a voltage on each pin should then be measureable.
Did you see this post you had asked for service manual:
https://www.badcaps.net/forum/showthread.php?t=21576Never stop learning
