Recovered a small electronics box at a college dumpster, I was thinking I might be able to use the box for something else, and/or salvage a few parts. Have uploaded a photo of the inside circuit board.
The only label on it is a generic supplier label, "Anachem", which seems to be in the area of biology equipment, though it's probably strictly not a biology device, it might be used in conjunction with one. None of the inputs/outputs have any labels.
"Front" panel has "on/off" switch, 2 LEDs, and two banana plug ports.
"Back" panel has 8-position DIP switch (white block in the photo), and what I presume is the power input.
The board inside has as you can see, a few resistors and capacitors, in addition to 3 variable resistors to the left (blue blocks) and a diode behind a power regulator on the upper-right.
The 4 socketed chips are as follows:
MC14040BCP - 12-Bit Binary Counter
MC14060BCP - 14-Bit Binary Counter and Oscillator
TS27C64A-20CP - 64K (8K x 8) CMOS UV EPROM
ZN428E-8 - 8-BIT LATCHED INPUT D-A CONVERTER
And the power regulator:
LM2940CT-5.0 - 1A Low Dropout Regulator
Anyone know what it might have been used for, or is it fully dependent on what was put on the EPROM? Any clues on the possibilities based on the components used?
