I was wondering: if you remove a capacitor from a circuit, you test its ESR and it seems fine for its stated capacitance, does it mean the capacitor is fine? Would an additional capacitance test be relevant? I'm asking this because I'm already using an ESR meter, my multimeter doesn't test capacitors, and I was wondering if an additional capacitance meter/multimeter would be worth the investment for hobby repairs. Does the ESR test (out of circuit) make the capacitance test obsolete? Sorry if it's a stupid question, I'm a beginner.
Is testing ESR enough?
Re: Is testing ESR enough?
And just to be clear: I know that ESR and capacitance are different things, and that ESR can be measured in circuit.
Also, another question: why do most multimeters that measure capacitance only go as high as 20uF-200uF? I've seen 2200uF electrolytics in PSUs and 3300uF on motherboards, so higher capacitances are pretty common. Is there a problem with accuracy, maybe?Last edited by cib3k; 11-04-2013, 05:04 PM.
Originally posted by cib3k View PostAlso, another question: why do most multimeters that measure capacitance only go as high as 20uF-200uF? I've seen 2200uF electrolytics in PSUs and 3300uF on motherboards, so higher capacitances are pretty common. Is there a problem with accuracy, maybe?PeteS in CA
Multimeter s perform capacitance measurements at very low test frequency of few Hz.
Therefore they are worthless for Very low ESR capacitors which require 1KHz or higher as test frequency so to be calculated all parameters as Q / ESR / Capacitance.
In conclusion anything less than a complete LCR bridge is a toy.
