Inverter tester using old CFL
This is a sticky topic.
    Re: Inverter tester using old CFL
    Can I use this method with a CFL to test this inverter? It's from a 42 inch TV. There's one transformer driving all the bulbs. Would I just hook one CFL up between the two inverter outputs?
      Originally posted by Measuray View Post
      Would a device like this workout more better?
      http://www.lcd-pdparts.com/ViewDetai...ProductID=1813
      CCFL & LCD TV Monitor Backlight Tester
      VIP Price:$16.30
      thats for testing ccfl tubes,the bulbs in question will test the inverter for soundness
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        thanksssssssssssssssss
          Another tips for using CFL for testing:
          https://www.badcaps.net/forum/showth...x+dx-40l261a12
            Do you know if these bulbs cause any more stress to the inverter than the correct CCFLs?
            I ask because I had the idea to use this to test a couple of monitors which shutdown after 10-20 minutes rather than a few seconds. Would it be OK to run the monitor with these CFLs for that long?
            -David VanHorn
              from my studies on arc tubes you should be fine. just don't expect much lite out of that CFL tube.
              Follow the white rabbit.
                Do you mean "Light" or was that a typo of "Life"? And if the latter - why?
                -David VanHorn
                  that was an auto carrot of light, sorry.
                    No worries, might give it a go tomorrow then.
                    -David VanHorn
                      Lol too funny.
                        Originally posted by mmartell View Post
                        Lol too funny.
                        sometimes i wonder if the google devs are screwing with people.
                          Do not throw away those broken CFL (14Watts or smaller), you can use them for testing your LCD monitor inverter circuits without buying spare lamps for testing.
                          You can solder the wires directly to the connectors on the inverter board or you can get the correct connectors but then you have to have more than one type.
                          I tested it out on my lamp tester board as you can see in the pictures.
                          I open up the lamp assembly using small hack saw just enough for me to crack it open, just be real careful.
                          Enjoy!
                          great stuff,
                            Useful info - stickied
                              I guess you can use the same method on an LCD TV but there are many more lamps, is that practical?
                                Yes, that is the point of the thread isn't it? It is for testing inverter outputs, not replacing bad tubes.
                                  Great idea, Thank you.
                                    Do all these techniques will apply to testing inverter for 40" TV or I need to use different bulbs?
                                      VIP Price:$16.30
                                      Seems so, but i think an old monitor inverter could do the same.
                                        Thanks man well good information ........
                                          Good idea todai check
