I did a job for someone and she gave me a Vizio E470VA. She said lightning had struck and the TV no longer worked. Before throwing it away, I decided to test it and see what I could find.
When the set is plugged in, the word Vizio below the screen lights up. It will then go off again. I can turn the set on with the remote, but I can see the entire screen flashing. It will go light and immediately dark. The flashing is very rhythmic and alternates about every second. I did an extensive search and could find no similar conditions. Also, while the screen is flashing, the Vizio logo below the screen does a very similar type of alternating between light and dim.
I pulled the PSU and tested it today. I got proper voltage on each of the pins, but they fluctuated a bit. I also noticed a faint clicking around the lower corner of the board. That clicking has the exact same rhythm as the flashing I described before. I'm attaching two pics of the board, in the hopes that someone might be able to help me figure out where the clicking is coming from and whether I should replace the entire board. If I can replace a component, I would rather do that.
Thanks!
Gary
Edit: I also uploaded a pic of the sticker on the board. The center pic is of the corner of the board where the faint clicking is coming from.
Thanks!
Gary
