PSU = AcBel API4ST03. Pic attached.
iMac automatically attempts to boot without pressing power button when power cord plugged in. LED1 is on, LED2 flashes on briefly every few seconds along with HDD and ODD fan kicking just slightly. LED3 never comes on. ODD makes no noise, HDD is removed. This pattern repeats indefinitely. Known good PRAM battery installed, PRAM reset performed. I understand we have trickle power with LED1, LED2 shows logic board is attempting to start and failing every few seconds.
PSU makes a 2 noticeable sounds
- Buzzing sound whenever power cord is plugged in
- ~2Hz clicking/arcing sound if PSU is disconnected from logic board (either at the 5 pin PSU output connector or the 2x7 logic board connector) Sound file is here https://drive.google.com/file/d/0Bwn...ew?usp=sharing
- Disconnect the Inverter board makes no difference on the sounds or boot pattern
- Can't really isolate which component is making the buzzing or cycling noise.
PSU output measurement shows 12V on both grey wires. 0V on brown
PSU did have 1 bulging cap (1000uF 16V). I've substituted with some cheap Chinese cap (1000uF 25V, black color next to output wires) I have for now (I've read this forum and know I should get better caps) But for now PSU doesn't behave any differently before or after this cap replacement.
Couple of resistors have blemishes on top. See yellow arrows on the pics. Just to the right of the lower left arrow is the 2 solder points for one of the blue caps with some blemish between. Looking at the capacitor legs from the other side, I see no sign of leaks.
I guess here is my question
- Based on the LED patterns + 12V PSU output, and noisy PSU, is the problem further downstream in the logic board or could still be the PSU?
Thanks for any thoughts in advance. My knowledge is digital+computer science guy so analog+power supplies are beyond me
