Re: Samsung LN-T3242H works fine for a day, then wont turn on. intermittent.
Yes, I saw that link last night when I searched the forum using the CMO inverter board model number, in that thread, the OP does not have the 24V for the inverter due to blown 0.22 Ohms fusible resistor int eh power supply board.
The OP also said this "
ADDITION : The 4 blinks then steady Red Power LED is NOT an error code. It did the same thing every time i turned it on. So my guess is, it is a normal start-up procedure"
He probably should remove the glues so he will not have bad brown glue problem in the future.
