I've built the ESR meter that I found at this address.
My digital DC Voltmeter got no button to set ZERO volt on display, so when I supply the 555esrMeter the two boundaries are:
No cap at test point = 1.355V
Shorted test point = 0.069V
The fine adjust sensitivity 1 V/ohm is not working properly in my circuit so please don't think the value is the real esr in ohm.
I've tested over 100 different electrolytics with this circuit, but I don't understand how much reliable this meter could be.
For example: I've tested these 47uF electrolytics:
[year 2011, new] Sanyo ME AX 47uF 100V = 0.108
[year 2010, new] Yageo SEK 47uF 250V = 0.226
[year 2008, new] Jamicon TK 47uF 63V = 0.182
[year 2002, used] Lelon RGA 47uF 50V = 0.200
[year 1991, used] Rubycon CEW 47uF 100V = 0.208
Then I take 3 Roe electrolytics, 47uF:
[year 1987, used] ROE EGD 47uF 250V = 0.082
Could it be? After 24 years they are better than a modern low esr 47uF electrolytic such as Sanyo?
