Yeah, they should work just fine but you might want to check the data sheets of the (most likely) Ltec caps you are replacing in the PSU. My favorite are United Chemi-Con KY series caps, ever since one of the members recommended them to me I've been using them for almost all of my PSU's recaps.
Yes, I think mixing ZL and FM is fine... They're pretty similar in spec.
If you're going to go through the trouble of re-capping the PSU, you should do a total re-cap. If you posted pics and a detailed list, someone can find you the best caps to use.
Yes, absolutely. The daughterboards with PWM and 5VSB chip should also have some small caps that should be replaced. If you use wick on the pins, you can lift out the board so it can be worked on.
What exactly are the symptoms with this PSU? How do you know caps are the problem?
