I'm having a problem with an ASUS P5KE that ASUS sent me as a replacement for an older mobo on warranty.
It has four memory slots. The two yellow ones are A1 and B1. Those are the ones I need for dual channel.
The problem I am having is that the board only posts when I have memory in the A slots but will not post if I have any memory in the B slots.
They replaced it a few times. Some times they confirmed the problem, Sometimes they said it worked for them, but then I had the same problem again.
I also tested different memory. I even sent them my memory, and they say it worked for them. They tested it outside the case, with a video card, so they could see that it booted, but they did not have sound so they could not hear the post beeps.
I tested it in the case without a video card, and relied on the post beeps to see if it posted ok.
They suggested that I test it outside the case, to see if that makes any difference.
If you want you can watch this 15 minute video to see how I tested it.
http://rapidshare.com/files/213167231/asusp5ke.wmv
Any ideas on what the problem could be?
