Olevia 327-S12 Monitor, vertical lines fade out backlight on
    I am looking for some help on this Olevia 327-S12 monitor.
    Blue light is on, press power button, display shows various color vertical lines which fade out after about 3-4 seconds. The backlight comes on and stays on. I see no visible bad capacitors. I have used DMM to verify voltages on power supply board, connector CN903 has 12VDC on pins 1 & 2. Connector CN904 has 5.15VDC on pins 4,5, & 6. These voltages are also getting to the system board connectors CN3, CN4, & CN5.
    I have checked all fuses I can find and they seem fine. I have checked the output transformers and they measure 1.1K ohm and all measure the same.
    This is my first post so any assistance would be appreciated.
    Thank you.
