I was reluctant to asking but I already spent hours trying to find out what's wrong with this PSU.
Apparently no schematic is available so I did a little bit of reverse engineering. The problem is that the inrush current relay turned on, the PSU tried to start and then turns off.
Here is what I did:
- took the PSU board out of the TV
- connected two switches from 5Vsb to RLY-ON and VS-ON via two 1k resistors
- the 5Vsb was ok but when I started RLY-ON no output voltages 5Vsc, 9Vsc etc., PFC is ok 365VDC output
- found there was too much ripple on the capacitors of the NCP1203 flyback circuit, checked them and they where BAD indeed
- now the 5Vsc, 9Vsc, 12Vsc, 24V work (MR2920 converter)
- I flip the switch for VS-ON
- Va is ok (another MR2920 converter), about 60V
- Vs is not ok (done with a MR5060)
Here is where I'm stuck. VS workes occasionnally.
MY QUESTION:
The NCP1203 creates 2 separate voltages, about 9 to 10V for its own VCC and about 16V for the power supply of the MR2920s and the MR5060 (VS). The 16V also supply the inrush relay. This voltage drops to about 14V when supplying the MRs and the relay.
This voltage seems to be too low to me.
Relay coil voltage spec: 18V
Undervoltage lockout NCP1203: up to 8.4V
MR2920 startup voltage: >14V
IMO the NCP1203 works at the wrong output voltage and I can't see why. The voltage feedback is done with a TL431 and it gives out 5.1V on the secondary side, exactly as it should be from what I see. Everything around the NCP seems to be ok, switching frequency 100kHz, MOSFET, gate resistance, voltage clamp... apart from its output voltage of 9V and 14V.
IF ANYBODY HAS AN IDEA WHAT'S GOING ON OR HAS A SCHEMATIC IT WILL BE MUCH APPRECIATED.
Thanks for reading.
Here is what I did:
MY QUESTION:
Thanks for reading.
