Dell 1703FPt Flashes on then off
    I have a Dell 1703FPt that will flash on for a second then off. The image is still there just the inverters appear to be shutting down.
    With an ESR meter I found c809 to be bad. I have also replaced the caps that are green (this was before the esr Now I am stumped would appreciate the help.
    No apparent burns on the inverter xfmers
    This is the one piece psu/inverter design. See attached pics.
    Keith
    Re: Dell 1703FPt Flashes on then off
    Sounds like 2 seconds to black. The following post is a Guide to Troubleshooting "2 Seconds to Black."
    Issues can include bad capacitors, bad transformers, bad ccfl's or ccfl wiring, bad transistors, etc.
      Have you checked the pico fuse ?
        I agree .read the guide. Personally I would try and check the inverter transformers first. I was trying to read the numbers off the one on the right to advise you which were the secondaries but couldnt quite make it out. Nor could I read the power supply board number. It is usual to have pictures looking straight down so that these can be read along with other board information. You should also post a picture of the underside.
          I found it!!!!! shorted wire on one of the CCFL's
          Thanks for the input guys!!!
            Well Done!! Dont break it putting it back together
              I HATE it when that happens.
                ??? if the backlights flash then the fuse is obviously intact.
                Friends don't let friends buy Samsung ....
                  Had it happen to me before backlight flash pico on its way out changed and cured the fault .
                  Since then just change them anyway to play safe
