This computer monitor would turn on (very dim a loud buzzing), then go black after a couple of seconds. It had to be power cycled several times until it would finally stay illuminated. The blue power light would stay lit when the monitor would go black.
I went ahead and replaced all of the main capacitors and it still doesn't work. However, the problem seems to be different than before because now it turns on for about 30 seconds, then completely shuts off and won't turn back on until I remove power, disassemble, then reassemble it. The picture looks great for the time that it's lit up. I'm at a loss now. I'm fairly certain I used compatible replacements, but I've included the package labels for anyone to help me out and verify.
The first 4 pictures are from before the replacement. (One of the caps is just loosely positioned in place which is why it's off center). The rest of the pictures are from after the replacement. Maybe you can see something wrong that I can't. Thanks for any comments and suggestions you may have.
