I have an HP W2338H that when turned on will brighten up for a second, then go to black. Then with a flashlight I can see the monitor status and check cable. I have read around the forums and have had no luck so far in figuring it out. I sliced into the sheath of a pair of the CCFL wires going from the inverter to a CCFL and when it's first turned on, my multimeter reads decent ac voltage for a second and then goes to zero. All of the caps look fine, and as far as I can tell, no cold solder joints etc. I am a complete rookie in all this so bear with me! Any help or suggestions would be greatly appreciated! Thanks!
