HP Pavillon 17-f166nf boot loop
    As you can see on this video : https://youtu.be/XDtxhd0UFYM ; I have an HP Pavillon 17-f166nf which does not want to turn on.
    After pressing power button, power LED turns on and fan starts to spin for a second, then it powers off, then again LED turns on and fan starts to spin.
    Corrupt BIOS? Reflow needed? Something else?
    I measure only 22 ohm on some caps under GPU. Is it dead?
    Some caps under CPU shows around 70 ohm but I think it's alright.
    Attached are some photos of the board, original BIOS backup, and schematics (may not be exactly the same but close enough).
    Re: HP Pavillon 17-f166nf boot loop
    Seem bios problem
      Do you have a dump for this one?
        flasher avec ce fichier
          Thanks but it still doesn't work… Nothing changed with your ROM.
            Tried to remove PL12, PL13, then removed GPU as I was suspecting it. Nothing changed.
            Removed PL14 just to see what would happen, and nothing changed either.
            I've no other idea. Could it be a dead CPU/PCH? How can I test it? Anything else I can try?
              Thank you so much work for me
                Thanks I just download i will get back to you with updates mate thanks for sharing
                  Thanks its worked for me .
                  But power on message is" Manufacture Programming Mode is in Unlock mode"
                  and invalid Board sn/ model
                    Need uma bios
