I bought a Syncmaster 223BW display knowing it was defect and hoping to only have to replace some caps. Sadly this didn't fix the display.
Issue:
When plugging the power in, the LED blinks slowly, screen stays black. Connecting a pc does not have any effect.
I did replace some old caps that were bulged. I made a picture of the old ones and tried to get some shots of the new ones. Sadly I didn't know that I had to use specific ones. I only bought caps with the same specs.
I also did measurements of some parts.
CN2 Connector on Power Supply:
The following are from the logic board (since I dont have pin numbers, I will refer to #1 as closest to the top of the board (ribbon cable) or closest to left of the board (power cable in):
It looks like IC702 is way of and IC601 is just a bit more of than 1%. Could this be causing my problems?
I only replaced 5x 820 uF and 1x 330uF caps on the power supply board. But I image as the CN2 voltages are alright there is no immediate need to replace the rest.
The 2 fuses on the power supply board seem to be alright (very low resistance).
Any ideas what else could be bad?
Issue:
Code:
1 - on/off = 0.015 2 - A-Dim = 4.56 3 - 13.5V = 14.25 4 - 13.5V = 14.25 5 - 13.5v = 14.25 6 - GND = 0 7 - GND = 0 8 - GND = 0 9 - B-DIM = 4.93
Code:
Part IC602 17-18 #1 = 3.79 #2 = 1.79 #3 = 0 Part ic204 6p806 #1 = 5.16 #2 = 0 #3 = 5.14 Part ic601 17-33g #1 = 0 #2 = 3.25 #3 = 5.16 Part ic702 1501-50 #1 = 14.26 #2 = 5.92 #3 = 0 #4 = 5.16 #5 = 0 CN200 #1 = 0 #2 = 1.8 <- Goes to 0 when power Switch is pressed #3 = 1.8 #4 = 0.28
