In looking for a new Iron, I have researched lots & lots of fancy digital soldering stations and all the pros and cons, eventually leading to the venerable, tried & true Weller WTC/TC/TCP series station+iron. The kind /w the Curie magnetic switch where the tips determine the temp.
These are still in use today & new models still being manufactured, for over 50yrs. now. Not to mention their service-ability and the fact they don't need to be calibrated periodically like the digital units do.
I figure if it's good enough to manufacture the Apollo LEM @ Grumman in the 60's, then it's good enough for today's work too.
They never had a problem /w the LEM, unlike the CSM.
The units I'm looking at are the base station units. Really, I'm going to buy an older, used unit as their life expectancy is in the neighborhood of 20-25yrs. before needing any major service; element, transformer, cord, etc..
The max temp, determined by tip type is 800deg F. Tips come in 600/700/800 temps. The iron is rated for 48w, the base station is 65w. I assume this is for standby power to maintain a constant temperature for element heat up surges, yes?
Here's my question..
- Is 800F enough to do Pb-free motherboards, even ones with large grounding planes like server boards & Apple's?
*I'm unsure as I get conflicting information and it seems all the fancy digital units for Pb-free SMD rework/reflow are 850F. Will the unit/series I'm looking at be fine?
Second question set.
Lastly, I read over at Green Bay Professional Packet Radio that the magnetically controlled units are bad because the magnet can damage components.
Really??? Magnets aren't that hard on electronics, unless it's a CRT tube you're talking about. Surely this is utter hog wash, considering NASA (talk about sensitive equipment) used them and every other major tech company in the 60's. Thoughts?
Thanks for all your help and thanks for looking/reading.
