Pair of Dell SNPJ0203C/1G in an ASUS K8N?
    Hey all, do you think Dell SNPJ0203C/1G
    https://www.txmicro.com/Dell-SNPJ020...Hz-p-5234.html
    would run well in an Asus K8N Motherboard?
    ASUS K8N Specs - CNET
    I can get a pair for $20 local. I am reinventing my PC with Linux Mint Xfce ( a few weeks ago really) and would like an extra gig of ram. I currently have 1 512, and 2 256 sticks of mixed brands and speeds. It does show one gig at 333, so it works, but a pair of PC3200 would be really nice
    Re: Pair of Dell SNPJ0203C/1G in an ASUS K8N?
    That board will support up to 3GB of memory so you should be fine. The memory you are adding appears to be Low Density which is good and should work fine with that board.
      Yes, it should work. I haven't looked at a ram module support list for this motherboard, but it supports up to 400MHz (PC-3200) ram so as mentioned by the person above me, as long as it is low density it should work without any problems.
      Keyboard not detected, press F1 to continue...
