I have a E197FPf monitor with a squealing transformer that bridges the primary and the secondary denoted as SPW-053.
I have recapped all electrolytic capacitors with Rubycon low ESR caps, all except the large filter capacitor C854.
Q850 (MOSFET transistor?) seemed OK when testing following this video but I don't have the values for the forward voltage written down and it is back in circuit now.
The U850 (power controller?) chip has the following readings using pin 1 with the black probe
Pin 3 = 15.33v steady
Pin 7 = 15.11v steady
The large filter capacitor C854 has 332v.
When I press and hold the power button there is a tiny voltage increase on pin 3 and pin 7, exactly 0.01v.
D854 (dual diode?) I don't know how to test, but I think it is fine (can't quite read the part number).
I850 (octocoupler?) has the following
Pin 1 = 9.98v steady
Pin 2 = 8.92v steady
Pin 3 = -160.5v to -163.6v unsteady
Pin 4 = -158.8v to -161.6v unsteady
Probing pin4 changes the sound of the squeal until I remove the probe.
Transformer testing
Continuity
Primary1 - 1+2 - beep
Primary2 - 3+4 - beep
Secondary1 - 5+6 - beep
Secondary2 - 7+8 - beep
No continuity between primary1 and primary2 (1+2 and 3+4).
No continuity between primary1 and either secondary1 or secondary2 (1+2 and 7+8 or 1+2 and 5+6)
No continuity between primary2 and either secondary1 or secondary2 (3+4 and 5+6 or 3+4 and 7+8)
I have tried testing with an Anatek Blue Ring Tester and I only seem to get a green reading on pins 1+2 of Good/High Q, both sets of pins on the secondary appear to either be dead/shorted (no light) and the primary2 (pins 3+4) show red which indicates Bad/Low Q according to the label on the tester.
Any clues on what to replace? I was thinking the transformer, and I have removed it and tested it as above, I have put it back in the circuit and it still squeals. I'm unsure of the results of the test and if it isn't receiving what it needs then it's not likely to be the problem part, but I would need more information regarding U850 voltages to be certain that's the place to start.
Additional info
The button flex wiring harness
Pin 1 - 1.24v steady, drops to 0 when menu button pressed
Pin 2 - 1.24v steady, drops to 0 when "-" button pressed
Pin 3 - 1.24v steady, drops to 0 when "+" button pressed
Pin 4 - 0v steady
Pin 5 - 0v steady
Pin 6 - 0v steady
Pin 7 - 0v steady
Pin 8 - 1.24v steady, drops to 0 when power button pressed
Thank you for looking and hopefully you can help or ask budm or PlainBill to drop by
Transformer testing
Continuity
Additional info
Pin 4 - 0v steady
Pin 5 - 0v steady
Pin 6 - 0v steady
Pin 7 - 0v steady
