Hello, i own a EVGA X58 SLI LE motherboard that i bought from ebay as untested/not working for cheap.
For my surprise it was working and I've flashed the latest bios, after that i've modded the board so it would work with dual QPI cpu's aka cheap hexacores
I've followed this diagram:
It was fairly easy just shorting a couple of pads...inserted a xeon hexacore and it fired at first try, it was all good till I've tried to overclock the cpu the board doesn't adjust the vcore regardless of the value i dial in on the bios it will always be@stock voltage, but it does compensate for LLC and even adjust stock voltage for different cpu's.
The board does have one cap in bad condition but i don't think this could be causing this issue.
Anyone have an idea of what could be the culprit?
