hp 2009F SB520 diode always shorted
    i have HP 2009F LCD monitor, problem is "no power", when i check the power board one of the diode SB520 is shorted..i try replacing both of them with same value and it works, but only a couple of minutes..
    can anyone help me find out what cause this diode shorted?
    thanks,,,,
    Re: hp 2009F SB520 diode always shorted
    1) Post clear top down view pictures of all your boards following my sig file below exactly.
    2) Here is an example of how the picture composition should look like
    https://www.badcaps.net/forum/showpo...94&postcount=1
    3) Post a clear focused closeup picture of the diode and its surrounding components. The picture should be clear so we can read the pcb designations (use macro mode on your camera).
    4) Afterwards, we can make suggestions.
    --- begin sig file ---
    --- end sig file ---
