That's a diode. Perform these testing procedures in diode mode on your meter (pins numbered from left to right). You may have to remove the diode from the board if the readings are funky.
Test 1:
Pin 1 - Pos lead, Pin 2 (or the tab) - Neg lead. Expected Result: Reading of around 0.5V
Pin 1 - Neg lead, Pin 2 (or the tab) - Pos lead. Expected Result: Open or "OL"
Test 2:
Pin 2 (or the tab) - Pos lead, Pin 3 - Neg lead. Expected Result: Open or "OL"
Pin 2 (or the tab) - Neg lead, Pin 3 - Pos lead. Expected Result: Reading of around 0.5V
That is Dual diode with common Cathode (the Cathode of bothe Diodes are tied together) in the middle big tab, the other two pins are the Anode, in this case, they are also tied together by the the circuit traces. So you can just treat and test this as one SINGLE diode.
Thanks capkid,
Here's my results of my test, there are two of these diodes on the board..
Test 1: doide1
Pin 1 - Pos lead, Pin 2 (or the tab) - Neg lead. Expected Result: Reading of around 0.5V .046
Pin 1 - Neg lead, Pin 2 (or the tab) - Pos lead. Expected Result: Open or "OL" .OL
Test 2:
Pin 2 (or the tab) - Pos lead, Pin 3 - Neg lead. Expected Result: Open or "OL" 0.000
Pin 2 (or the tab) - Neg lead, Pin 3 - Pos lead. Expected Result: Reading of around 0.5V 0.000
Test 1: diode2
Pin 1 - Pos lead, Pin 2 (or the tab) - Neg lead. Expected Result: Reading of around 0.5V .392
Test 2:
Pin 2 (or the tab) - Neg lead, Pin 3 - Pos lead. Expected Result: Reading of around .392
I removed diode 1 from the board to double check and getting the same reading. I take it this diode is bad.
I just took some new readings and I no longer have continuity to ground with the -VY resistor, and also the rings on the ipm as in this thread https://www.badcaps.net/forum/showthread.php?t=30592 . Wonder if this diode caused the ipm to go bad or vs versa. Should I look further for a cause to what blew out the diode?
Thanks, I went ahead and ordered the diode (and one spare )
Please correct me if I'm wrong.. Voltage flows into the anodes and out of the cathode and blocks it from flowing back(like a check valve)? The two anode spots on the board have continuity to ground. Could something else be bad as well, that trace to the anode spots causing it to ground? Or does it sound right to have anodes as ground?
Are both sides continuous to ground? Is the resistance to ground steady and under 5 ohms? If the resitance fluctuates up might indicate you're actually charging a capacitor that is bridging the anode to ground.
It's possible that the cathode of the bad diode is ground, and its "shorting" the anode side by being a faulty diode that's allowing reverse flow that is basically grounding out the anode side.
Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
"The two anode spots on the board have continuity to ground". That depends on how this diode is being used, if the Anode is connected to one wire of the transformer winding, and the other end of the transformer winding is connected to ground which is typical for half wave rectifying circuit, then you will see very low Ohms reading due to low transformer's winding resistance.
We need to see bigger pictures of this board to see how this Diode being used.
I see you mention Diode 1 and Diode 2, are they the same as shown in the picture?
Voltage doesn't "flow"... voltage is sort of like water pressure, and current is sort of like water flow rate. A diode in this case is similar to a valve which only lets water flow in one direction... but it's the "flow rate" it's blocking, not the "pressure" (current not voltage.)
The Anode of that D21 (both pins) are connected to the Ground plane, you can see the GND label on the PCB. It looks like it is for Buck regulator switching power supply. Cannot see D11 traces, but it may be the same for another buck regulator.
