someone dares to use lower ripple capacitors then the original, or lower esr for that matter?? I bet it would make nice fireworks a few months after use
What happens if...
Re: What happens if...
In a PSU, changing the ESR (either way) would probably not result in a fireworks display - it would just not be as well tuned to the PI filtering coils as the originals and so the ripple may be somewhat worse.
If you went lower ripple, the cap would just overheat, wear out anf fail quickly, and the ripple would skyrocket. Again, though, it probably wouldn't make a PSU go up in smoke.I love putting bad caps and flat batteries in fire and watching them explode!!
Read the last part here.
https://www.badcaps.net/forum/showpo...9&postcount=27
Excessive Ripple [which is AC] thins the oxide layer on the foil.
The oxide layer is the actual dielectric.
The thinner layer allows more DC Leakage current which further heats the cap.
When the DC Leakage current gets too high 'in spots' the cap the will begin to develop localized shorts that are beyond the electrolyte's capability to 'self heal' through the electrolytic chemical reaction.
In other words 'spots' of foil with permanent damage.
[That could happen fast or slow depending on how bad the conditions are.]
Additionally as the shorts develop the uF typically goes down because the surface area of the foil is being reduced.
Long term use with excessive Ripple applied eventually creates enough localized shorts that the overall condition of the cap is shorted or partially shorted.
At some point the excessive heat may [depends on the electrolyte] break down the electrolyte causing gas formation inside the cap [which is what bloating is] but it might not happen until very late in the failure.
If the failure occurs slowly you can have a very long period of erratic/unstable behavior from the degrading caps before they -visually- bloat.
They may never bloat at all if the failure is slow and the gasses manage to leak past the bung relieving the pressure.
.Mann-Made Global Warming.
- Dr Seuss
