I've been experimenting with the latest Ubuntu version 10.04 LTS [released April 2010].
I used the 'live CD' on a Windows XP box.
It was easiest least problematic install of ANYTHING I've done in years.
Everything just worked. [Except the Promise RAID card which I expected anyway.]
I didn't have to fuss with drivers.
Even the bastard "Marvell-Yukon" Gigabit LAN chip worked fine and installed by itself. [That bugger gave me fits in XP.]
In fact it was -easier- than installing W98!
Pretty much an 'unattended' install.
Test box was:
Abit IP35-E
4Gb RAM
Nvidia GeForce 7300 LE
Promise S150 TX4 [Promise doesn't support Linux - I knew that]
.. and a 500 GB drive on a generic USB adapter.
Tested because I'm considering using Mythbuntu 10.04 [based on Ubuntu 10.04] on a board that has the "Marvell-Yukon" chip and I wanted to know if I'd need an add-in LAN card to get it going.
- Nope! Linux now supports the "Marvell-Yukon" chip out of the box!
I knew the drives on the promise card wouldn't work but the NTFS drive on USB did. [I actually forgot the USB drive was attached.]
I will be switching to a 3-ware card for the actual build anyway.
Getting it running in Ubuntu [and getting online to check my eBay] took LESS time than just fussing the "Marvell-Yukon" driver in XP.
[It's a bitchy chip in Windows.. But some otherwise nice boards use it..]
LTS = Long term support version.
Desktop will be supported until 2013 and Server until 2015.
PDF and MS-Office ".doc" files worked without installing anything else.
The LAN auto-configured.
Sound worked without a hitch.
I tried everything I could think of and it all worked with zero fussing.
You guys can keep your Windows 7.
I won't be needing to PAY for the 'pleasure' of using an OS that won't work without 'politically approved' drivers.
I'm jazzed.
Linux seems to finally be 'there' even for average [non-programmer] folks.
Test box was:
Abit IP35-E
4Gb RAM
I'm jazzed.
