I want to bring to your attention a neat switching regulator drop-in replacement for the linear 78XX voltage regulators.
They come in vertical or horizontal packages and plug right into the holes that might be used for the TO-220. They are more expensive than a 78XX, but might be worth it if you otherwise have to dump a large input voltage through a linear regulator. Using the MuRata part, for example, would avoid the need for a large heat sink when using a 12v. input to a 5v. regulator running at 1 amp.
