Am going to replace the caps on a LiteOn PSU, and noticed that some of the original OST caps have lead spacings that are the wrong diameter, compared to the holes on the PCB.
Would the most likey reason be, that the manufacturer just used whatever was available, rather than caps with a lead spacing that matches the holes in the PCB?
So, in this instance is it a good idea to look for wider replacement caps, rather than matching the original dimensions?
One of them is way off in that respect - a 50v 10uf 3.5mm cap on the primary side, with leads stretched into holes that would suit an 8mm cap.
