LG flatron L1960TR
    LG flatron L1960TR
    Hi I'm new here and have a problem with my lcd monitor and believe this is the right place to ask for help.
    When I turn on the monitor it's very dark and needs about 1h to be as bright as it should so I opened the monitor and switching adapter. The switching adapter has 2 poped capxcon GL 1000uF 16V caps. Is this the reason for the dark screen? and with which caps should I replace them since in my country I could find only the following brands:
    Philips
    Vishay
    Jianghai
    YAGEO
    I'm guessing Vishay is good but what spec should it have?
    Regards
    Re: LG flatron L1960TR
    The Capxon GL datasheet is attached
    See how to match and pick the proper caps using my standard answer at (regulars may skip)
    https://www.badcaps.net/forum/showpo...84&postcount=3
    --- begin sig file ---
    --- end sig file ---
      If you update your profile with the country you live in there may be members there who can suggest other brands
        16V 1000uF CapXon GL is only available in 10x25mm case size. If that matches your bad ones, ESR is 0.050 ohm and ripple is 1180mA.
        Teapo/Yageo (same thing) SC 16V 1000uF is available in 10x20mm can size. That specific one has 0.039 ohm ESR and 1250mA ripple, so it should be an OK replacement.
        The only big drawback is that Teapo's don't like heat. So if the PSU runs hot, they might not last very long..
        It's not the best choice for this, but it should work fine, at least for some time (another year or so?!)
        Datasheet attached.
