The motor they came from is made by MOTOR SPECIALITY INC. model 3069 B2.
Do these motor brushes need replaced?
Re: Do these motor brushes need replaced?
The rotor is hard to turn with the brushes removed? The brush still have a log way to go.
The motor bearings still have any lubricants?Never stop learning
Either it uses the bushing or bearings, sounds like they are in bad shape.
Any pictures?Never stop learning
Can you easily turn the rotor since the rotor is attached to the other motor end bell housing.
They are just Bronze sleeve bearing, cheap! Put a fill drop of oil on the shaft and try to slide the end bell up and down to loosen up.Never stop learning
Use http://www.amazon.com/3-IN-ONE-10045.../dp/B00065VGUC
http://www.amazon.com/Markal-79704-S...d_sbs_indust_7
apply it to the shaft and rotate the rotor, clean off any gunk taht comes off, then re-oil it. The end bell in the picture, just put a few drops in the hole.Never stop learning
