Re: Choosing a soldering station
^ Doesn't happen to mine, I still think your tip is not clean. At over 350C which is well above the melting point of the most commonly used solders, you may be burning away the flux rather quickly.
You might just be trying to wet with far too much solder, wetting doesn't require a huge amount on a fine conical tip... it would pretty well defeat the purpose of having a fine tip if there were a lot of solder on it.
