the inverter in this set makes the 2 of the caps (18j 3kv) hot enough to melt off the inverter board..the other 2 caps seem to be fine any one got any suggestions?
himage 17" tv
Re: himage 17" tv
I hope someone else can answer this as I don't know.
But you could try swapping them around to see if the problem follows the capacitors or not. If it does the capacitors are probably bad somehow.
For better help from others, please post the model number of your TV, and also attach some photographs of the capacitors in question."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn
