Hello all,
I have a 3 year old Samsung plasma TV that I'm trying to fix. It's a PN60E6500EF. The problem started about a year ago when the TV just stopped working one night. The screen went dark and no red light at all ... dead like as if the power cord was removed. I opened it up and found the main ac fuse (F801S) on the power supply was blown. Long story short, I ended up ordering a replacement power supply board (BN44-00513A) from ShopJimmy.com. Installed the board and the tv worked great for about 6 months when the TV turned itself off and the red light started blinking. I can removed power, wait a few minutes, and plug it back in and it will usually work for a short period (< hour) before it powers off again. The time that it stays on seems to be less every-time I cycle power. I looked at the board and saw no obvious bulging caps or burnt components. I ordered the repair kit from ShopJimmy and replaced all the capacitors they included in the kit (CM802, CX851, CX857, CX858) but decided to wait on the other components for now since they are more involved to replace and I keep reading that capacitors are the usual suspects. When I reinstalled the power supply it seems to work normally and stayed working for hours longer than before but then it started again. When it turns itself off the red light will blink twice, repeating 5 times, then pause and repeat the blinking twice 5 times cycle.
Any help would be greatly appreciated.
PS: On the first power supply board, I also bought the repair kit for it and replaced all of the components. This made no difference. It is still dead as a doorknob and doesn't even blow the ac fuse.
