My syncmaster will turn on for a little bit then flicker then the screen will turn black but the power button will continue to be illuminated. I replaced 1 cap that was blown but it didn't help. Any suggestions?
Samsung syncmaster 216BW
I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Service Menu/Factory Reset Codes for TVs
http://www.badcaps.net/forum/showthread.php?t=24809Tags: None
Re: Samsung syncmaster 216BW
Thanks! So basically I have to replace all to resolve the problemI have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Originally posted by redwire View PostWhen my syncmaster did that, I just replaced them all. It's a few dollars to do. You save nothing given the time to take it all apart and put it back together.
Search the site, there are several threads on re-capping the 216BW and 226BW's.I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Thanks, i was pretty sure about that.I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Originally posted by henrysin44 View PostMy syncmaster will turn on for a little bit then flicker then the screen will turn black but the power button will continue to be illuminated. I replaced 1 cap that was blown but it didn't help. Any suggestions?Please upload pictures using attachment function when ask for help on the repair
Sometimes it will stay on for a couple hours but mostly like 15 seconds to 10 minutes.I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
I have replaced all of the caps. It will not shut off anymore but every once and a while it will flicker for about 10-30 minutes.I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
how would i know if a inverter transformer is bad
also the flickering will get much worse if the brightness is increasedI have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Fault on a inverter transformer doesnt come and go. What you can do is
resolder it - remove all the old solder and replace with leaded.
What make /series caps did you use to recap the board?
Sounds to me like it could be the lamps/wiring - when it is flashing can you hear anything
like arcing, Have you nay bulbs in anything you could substitute or another monitor you could try these bulbs with.
If neither how about making up some test lamps
https://www.badcaps.net/forum/showth...ght=test+lampsLast edited by selldoor; 04-07-2013, 09:53 AM.Please upload pictures using attachment function when ask for help on the repair
nichicon, i ordered the wrong ones, i dont know how but i had to replace the 830UF with 1000UF ones.I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Originally posted by henrysin44 View Postnichicon, i ordered the wrong ones, i dont know how but i had to replace the 830UF with 1000UF ones.I have salvaged and fixed 18 TVs (1 DLP), 22 LCD monitors, 8 stereos, network stuff, and more laptops and computers than i can count.
Sounds to me like you have a bad ccfl (lamp), bad wiring, or a faulty inverter transformer. Check out retiredcaps guide on 2 seconds to black. Especially the section that deals with ccfls and inverter transformers and how to test them.
Start at post #19
