Re: Toshiba M-9485C VCR
Have a look at the back tension arm, it should be resting against the tape and actually pushing the tape to the side a bit. If there was too much tension it would be puting too much brake on the supply reel causing the tape to go tight against the drum.
Another place to watch is how the tape is riding between the capstan and pinch roller, if there is too much back tension that can cause the tape to ride down the capstan causing it to crinkle at the exit guide, this would also cause it to ride lower on the ace head loosing the control pulse causing the capstan speed to be eratic. watching the action of the back tension arm can tell a lot about whats happening
