Hi
i have a non working SHARP LC46E77UN.when plugged to the power the power light turns on then i hear relay clicking sound, the tv stays black non back-light and after a minute or so, the OPC and Power light blink together 1 time, then The power light blinks 2 more time and the cycle repeats.
i downloaded the service manual (page 61) and its says if the power light blinks 3 times,then there's a bad communication with the main CPU.
i took the TV apart and i forced the TV to start ( vol+ and channel down and plugging the power cable in same time) and measured the voltages on the power board (model : RDENCA336WJQZ),all the voltages were ok expect the PLN 12V(the connector in left had side ( goes to the tcon board).
I also took the power supply board out and verified all the MOSFET, diodes and resistors and i didn't found any suspicious components.i also check the ESR of some caps and they are ok.
so to summarize, the blinking code says there's a problem with the main board and the logic says there's something wrong with the power supply ( there no voltage at all that goes to the Tcon board)
i have uploaded the tv service manual.can someone help me to fix the problem.
