I have another Dell 2005 FPW monitor with this problem. It has vertical lines thru out the screen. It not that the pic is blurry, but I took a small movie of the screen then took a screen shot of it. At least the screen comes on on this one. Maybe between the 2 I can make at least one of them work. Have not taken this one apart yet. Wanted to get some ideas first.
Another Dell 2005 FPW
Re: Another Dell 2005 FPW
that sounds like it could be the ribbon cable or logic board.
you said you had two of the same monitor, but the other one does not turn on?
you could, if they use the same internals swap the power board with the one that doesn't turn on, and might have yourself one of them working.
The other monitor can be found here.
https://www.badcaps.net/forum/showthread.php?t=44876
I would do it the other way round= as this screen is sort of working then the boards must be sort of working- so try the screen off the other monitor on these boards.
Did you have a known working source connected to the monitorLast edited by selldoor; 04-13-2015, 02:30 PM.Please upload pictures using attachment function when ask for help on the repair
OK I used the invertor board from this monitor and the main board from the other monitor and this is what I get now.
View My Video
Any thoughts?
I'd swap the PSU's from both of these monitors.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpic
Well I started trying to adjust brightness and contras and it has stopped making the arcing sound in the lower left hand corner and the screen is solid! Put it all back together and turned it back on and it was flicking just a little but went away in just a couple min. I'm thinking bad solder joint maybe?
Originally posted by Nightwolf View PostWell I started trying to adjust brightness and contras and it has stopped making the arcing sound in the lower left hand corner and the screen is solid! Put it all back together and turned it back on and it was flicking just a little but went away in just a couple min. I'm thinking bad solder joint maybe?Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpic
It's still a good idea to pinpoint the joint and reflow. Could you trace it?Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpic
AM radio is good for listening for arcs.Last edited by budm; 05-11-2015, 01:03 PM.Never stop learning
I would say you do have bad connection at the end of the lamp.Never stop learning
Yes.
Typical bad wiring:
http://s807.photobucket.com/user/bud...?sort=3&page=1
is this same one you have?
It uses six lamps!
Look at the corner back side of the screen to see if there is any signs of problem in that corner of the screen.
20" monitor may not be worth fixing, but you do have one bad screen that you can take apart, right? The one with bad lines does not make arcing noise, correct? otherwise you can swap the LCD glass panel to the with good lamps.Last edited by budm; 05-12-2015, 11:41 AM.Never stop learning
This is the one that had the lines through it. I put the other main board in it. Your second link is the one that was in the other display, both displays have 6 lamps, transformers has 6 leads on one side and 2 for the output side. This one, the transformers have 4 leads on one side 2 on the output side. I'm thinking I tried both screen and the other one flickers then goes out. Hope you followed all that. LOL
