Re: Philips 32PFL6606T 32" LED no back light
Right then folks.......FIXED!!!! WHOOOO HOOOO!
took the complete screen out and the glare sheets,
1. set my meter to diode check and went through all LEDs at there test points = all were fine
2. went from the connector that plugs into the board to the first and last LED and check them set at a time (A1 to Led 1 test point and C1- to LED 14(something like that))
3. found that the connector block on 2 of the LED boards had come away from the board
4. re-soldered
5. tested again on diode setting to check the first and last LEDs were working to the connector.....BINGO
6. re-assembled and tested.....didnt work.......forgot to put the t-con ribbons back in for the screen
7. put ribbon cables back in.....powered up and there she was in all her glory!!
this looks like it could be a common fault because the connector blocks on the LED boards dont seem that great, the tv i would say is brand new, so i guess when its been delivered it must have took a small knock and bust it off its soldered joint
THANKS EVERYONE FOR ALL THE INPUT, WITHOUT THIS FORUM I WOULDNT HAVE DONE IT, I HOPE THIS TOPIC HELPS SOMEONE ELSE OUT IN THE FUTURE
4. re-soldered
