Hanns-G HG281D issues again
    I thought I would start a new thread since I didn't want to hijack an existing thread.
    My symptoms are that after re-capping the power supply, I used the repair kit found on Amazon, my monitor worked for about 4 days, then last night it up and died. Nothing I could do could make it work. I thought I turned off the monitor, but when I came down this morning I found it on with a blue power light. I then attached a cable and could see a web screen I had up on my laptop which I left on last night. As of now, what is happening is that the monitor will work for a couple minutes at a time and then go black. The power led begins to flash ever so often, and then it goes amber to signify it has no signal. When I re-attach the monitor, it will flicker for a moment or two, the display the screen, and then a minute or two later go black again. Wondering if the logic board or the voltage regulator could be bad at this point?
    Any ideas?
