Have a panasonic TC P42C2 with 10 blinks. getting all voltages but Vda (0 volts) anybody have schematic for PSU on this model. block diagram has Vda generated by Q451 and IC 451 - Actual board doesn't have these ???? Looks like some sort of Vda detection circuit ???
Pana TC-P42C2 10 blinks
Re: Pana TC-P42C2 10 blinks
I believe this is a cut-down version of the X2 model (also 720p) but there's no schematic for that either, unfortunately.
Vda will only come up if the 5V or 3.3V for panel is present.
Loss of 5V/3.3V will cause a 5 or 3 blink code.
10 blinks is more likely related to the 15V. The 5V rail is usually bucked off the 15V, so that must be present for the Vda to come up. Forcing Vda with no 5V will likely result in a plasma panel driver being destroyed. (The control ICs MUST have 5V present before the Vda is. The PSU ensures this synchronisation.)
Check the F_STBY_ON
If that is going HIGH (>2V) then check F_STBY15V
If they are dead: try with A board out and jumper F_STBY_ON... if that comes back then you have a short on the A board. If not, then you have a bad P board.
If they are OK: more likely fault on A board - SUB9V, SUB5V, etc.
Picture of your P board?Last edited by tom66; 04-24-2014, 12:22 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
PSU. I got set dead - 10 blinks. ss and sn board had blown RF1501, RJP30E4, RFU20t%MS. replaced those - same 10 blinks. getting 15v, then fstb_15 comes on - then 0v.
checking stb 5v and f_stb_on now. curious - SM says LED lites on SS and SN board - can't find LEDs ??
F_STBY is 3.3V, F_STBY15V is 15V STB5V is 5V.
reseated all A board conns - (realized had SN2 connector off by accident- no Vsus to SN board.) now Vda comes up +55V - then dies 7 blinks now.
If I connect it back - all connections made - 10 blinks. seems like SN board bad.Last edited by ajshoe; 04-25-2014, 10:21 AM.
Originally posted by ajshoe View PostPSU. I got set dead - 10 blinks. ss and sn board had blown RF1501, RJP30E4, RFU20t%MS. replaced those - same 10 blinks. getting 15v, then fstb_15 comes on - then 0v.
When you first turn the tv on it will only be dim, goes full lit when the SN is running.
If you want to confirm PSU and A board are ok, you can do this. Disconnect SN2, SS11, P35, 3 white ribbons. power tv up and it should stay on, you'll be able to confirm all the voltages. Allow the voltages to bleed off before reconnecting SN2,SS11 and especially P35.
Most common failure with these is the TNPA5072 SS with the RJP30E4 IGBTs shorting out but I've seen a couple of threads where both SN,SS fail together.
generally either 4 or 10 blink. i had a 4 blink dead short on the Vsus at SS11 on mine.
I suspect that because you have the Sanken PSU, may be it's a copyright issue? The same PSU is also in some panasonic based Sanyos. No schematic in their manual either.
Mine has the LSEP1287 PSU and the schematic is in the SM for the models that have that one.Last edited by tw2005; 04-26-2014, 05:39 AM.
Got SN board from Potomac computers (boston) - claimed it was good (pulled form a cracked screen). Board had 4 mosfets dead short. didn't install it. Total hit or miss on EBAYers. I don't know how they keep their feedback rating at 100%.
TNPA5066AB is the board I have in this set (thats the one I ordered thats bad als0) - does anybody know if the suffix AC, AD, AE will work in my set ???
Originally posted by ajshoe View PostGot SN board from Potomac computers (boston) - claimed it was good (pulled form a cracked screen). Board had 4 mosfets dead short. didn't install it. Total hit or miss on EBAYers. I don't know how they keep their feedback rating at 100%.
or SJ
Both of these the majority of components are from new, damaged in transit unlike people who are salvaging from say the tip.
Any TNPA5066 from a 42" including the Sanyo models which also have the same panels will work.
Check SJ, they mention compatible alternates.
Originally posted by ajshoe View Postnew tnpa5066 fixed it. WOW - the side bufffer tabs are very finicky. took a while to get them seated properly. These panas have cheapen considerable. Like the older ones better.
